Posted April 30, 200618 yr comment_165603 i have change the the 4 transverse link bushings with the car is jack up,and tighten the 8 bolts ( with 3.2 kg-m ) that fix the transverse link. then i bring the car on there weels and a person with 60kg on the rear axle and tighten the transvere link inner bolts ( with 15 kg-m ) .....ready ???? so but now if the car bounces it sounds like a old door ??????? where is the mistake ????i hope sombody understand the quastion from a german with no good englisch language .!!!!!!!thanks:cry: Link to comment https://www.classiczcars.com/forums/topic/19847-problem-instal-transverse-link-bushing/ Share on other sites More sharing options...
April 30, 200618 yr comment_165640 Did you replace the original bushings with urethane? If so did you grease them well while installing? Urethane bushings will often squeek when installed dry. Link to comment https://www.classiczcars.com/forums/topic/19847-problem-instal-transverse-link-bushing/#findComment-165640 Share on other sites More sharing options...
April 30, 200618 yr comment_165667 Nicht sprechen zie Deutchse ....... but the grease is absolutely necessary for Polyurethane bushings. The final torque for the front inner bushings and the rear inner and outer bushings must be done "after" installing the wheels and the weight of the car is placed on them. That means you need a drive-on type lift to do final torque per spec. Link to comment https://www.classiczcars.com/forums/topic/19847-problem-instal-transverse-link-bushing/#findComment-165667 Share on other sites More sharing options...
May 1, 200618 yr comment_165712 germanZfan said: i have change the the 4 transverse link bushings with the car is jack up,and tighten the 8 bolts ( with 3.2 kg-m ) that fix the transverse link. then i bring the car on there weels and a person with 60kg on the rear axle and tighten the transvere link inner bolts ( with 15 kg-m ) .....ready ???? so but now if the car bounces it sounds like a old door ??????? where is the mistake ????i hope sombody understand the quastion from a german with no good englisch language .!!!!!!!thanks:cry:YOUR ENGLISH IS FAR BETTER THAN MY GERMAN WOULD BE IF I TRIED . Gary Link to comment https://www.classiczcars.com/forums/topic/19847-problem-instal-transverse-link-bushing/#findComment-165712 Share on other sites More sharing options...
May 1, 200618 yr Author comment_165715 =Enigma= said: Did you replace the original bushings with urethane? If so did you grease them well while installing? Urethane bushings will often squeek when installed dry.now i know the mistake i forgot the grease.Thanks !! Link to comment https://www.classiczcars.com/forums/topic/19847-problem-instal-transverse-link-bushing/#findComment-165715 Share on other sites More sharing options...
