Posted May 1, 200618 yr comment_165750 Does anyone have any tips on how to tighten the crankpulley bolt down withought the car moving? Does any one know the torque setting as well? I sure do not want that bolt coming loose. Link to comment https://www.classiczcars.com/forums/topic/19868-torque-setting/ Share on other sites More sharing options...
May 2, 200618 yr comment_165831 Put an adjustable crescent wrench on the camshaft knobs in between the fourth and fifth lobes and torque the cranshaft bolt to 100 ft lbs Link to comment https://www.classiczcars.com/forums/topic/19868-torque-setting/#findComment-165831 Share on other sites More sharing options...
May 2, 200618 yr comment_165841 I'm sure that Shane means 'camshaft'. I use a long breaker bar and socket on the crankpulley bolt. With that against the ground it holds the engine in place while you torque the cam bolt. Link to comment https://www.classiczcars.com/forums/topic/19868-torque-setting/#findComment-165841 Share on other sites More sharing options...
May 2, 200618 yr comment_165878 Thats what I meant, but he is trying to torque the crankpulley bolt, or am I wrong! Oops I meant to say crankshaft, I just now saw that. Link to comment https://www.classiczcars.com/forums/topic/19868-torque-setting/#findComment-165878 Share on other sites More sharing options...
May 2, 200618 yr comment_165909 My bad! He is talking about the crank pulley. I just read it wrong. Link to comment https://www.classiczcars.com/forums/topic/19868-torque-setting/#findComment-165909 Share on other sites More sharing options...
May 2, 200618 yr Author comment_165910 So I need to take the valve cover off to put the crescent on there right? Will that scar it up or any thing? Link to comment https://www.classiczcars.com/forums/topic/19868-torque-setting/#findComment-165910 Share on other sites More sharing options...
May 2, 200618 yr comment_165913 There's a spot in the area of the camshaft where Shane mentioned that you can tighten the wrench against. I put a block of wood between the head and the other end of the wrench. Link to comment https://www.classiczcars.com/forums/topic/19868-torque-setting/#findComment-165913 Share on other sites More sharing options...
May 2, 200618 yr comment_165917 I started to think that I read it wrong. But, no it will not scar or hurt the camshaft that is what the notches are for. Link to comment https://www.classiczcars.com/forums/topic/19868-torque-setting/#findComment-165917 Share on other sites More sharing options...
