where is the clutch slave cylinder on a 280Z model
You will find that little sucker mounted to the right side of the transmission bell housing. A hard hydraulic line runs from the clutch master cylinder (mounted on the firewall next to the brake master cylinder) down to the slave cylinder. There is a short flex line that connects the hard line to the slave. Time to crawl under the Z!
