I have 2 problems to solve. I need a rear defogger and the heater switch to "plug" in. I found out the defogger wire coming out of the console is not hooked up. Where do I look to find the 3-wire connector?
I apparently did not plug in the heater switch. Where do I look for the connector?
If anyone has done a dash or has one apart, can you please give me some help with this wiring? All I need is to find the connectors and plug them in. I have a "small guy" coming to help me on Friday. I am hoping I can tell him where to look. OK, guys??
https://www.classiczcars.com/forums/topic/19907-wiring-question/
send a PM to escanlon He will know
When I was doing the wiring replacement on mine, I found that there were lots of changes starting in 1/71, so any comparisons to mine aren't necessarily valid.
FYI - When looking for a replacement harness I found that the harnesses seemed to change every few months of production. Your best bet is to hunt down someone with a similar 2/71 car who might be able to look at their wiring.
Well...not sure if this will help, but here's a pic of my 5/72 heater control panel from the rear (with notes). If it's confusing, just ignore it. I know the defog wiring's probably different given console differences, but the heater wiring may be similar and of some benefit.
Good luck,
Steve
XRay and others... I have found the short in the heater fan. It now is working. I cannot find the connector for the R/Window defogger. Looking at your pic, it looks like the connector below the heater connector is like the one I need. I have the console switch but cannot find the connector. Anyone know which connector is one is?
