Posted May 4, 200618 yr comment_166191 I am just finishing my offset 3 gallon "fuel cell" and Design Products (old Tilton style) camber plates installation. If I can figure out enough insulation I will be moving the muffler to that side too to help offset my fat a**. Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/ Share on other sites More sharing options...
May 5, 200618 yr comment_166208 It's so CUTE! Looks good. Plenty strong for the 20 lbs of gas you'll get in there. Moving the muffler is not a bad idea... Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166208 Share on other sites More sharing options...
May 5, 200618 yr comment_166301 Think rear diffuser before moving anything else around back there. Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166301 Share on other sites More sharing options...
May 5, 200618 yr comment_166302 I don't know about cute, but it looks good, haha. Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166302 Share on other sites More sharing options...
May 5, 200618 yr Author comment_166315 It has an Earls filter-pump and Fram filter all on it as a unit so it is heavier than it looks in the photo. I was going to hang the muffler off of it too. Diffusers aren't allowed in FP or XP. I posted a picture of Darius's diffuser on SCCA forums.com and everyone seemed to think no way. I am thinking of a Scirroco radiator in the rear though which is allowed in both FP and XP. Hmmm, if I tilt the radiator at 7 degrees like John did with his fuel cell........ Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166315 Share on other sites More sharing options...
May 5, 200618 yr comment_166327 A diffuser isn't allowed in ITS either, but Keith Thomas built one pretty much the way I did with a 7 degree rise on the bottom of the fuel cell. I put the muffler on one side of the cell and a flat fuel pump/filter mounting plate on the other. Worked pretty well. The 7 degree rise on the fuel cell was to make sure it meet the SCCA 6" ground clearance rule. Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166327 Share on other sites More sharing options...
May 5, 200618 yr Author comment_166331 I made the fuel cell unit to sit on top of its mounts so I could add spacers for the 6 inch clearance rule. I am trying 23.5 diameter tires and 25 inch diameter tires in the rear. It is set up at 6 inches for the 25 and can be spaced for the 23.5. Maybe a sheet of aluminum set at 7 degrees to "route" the exiting radiator air. Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166331 Share on other sites More sharing options...
May 5, 200618 yr comment_166340 Why the radiator in back? I'm guessing it's to move weight rearward, but by the time you run tubes back and forth aren't you adding a bunch more weight? Maybe you're underweight and it doesn't matter. Anyway, just curious... Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166340 Share on other sites More sharing options...
May 5, 200618 yr Author comment_166341 Yes to move weight to the back. If I run FP I am under weight and you can't set the engine back. Here is a picture of Jesus Villalreal's 400hp V6 Camaro and his radiator air inlet in the side window Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166341 Share on other sites More sharing options...
May 5, 200618 yr Author comment_166344 Here is a photo by Mark Mervich on baautox.com of the car at the Atwater National Tour. Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166344 Share on other sites More sharing options...
May 5, 200618 yr comment_166359 Why the radiator in back? I'm guessing it's to move weight rearward, but by the time you run tubes back and forth aren't you adding a bunch more weight? Maybe you're underweight and it doesn't matter. Anyway, just curious...For autox any weight you can remove off the nose and towards the back will help the car rotate quicker. I'd move the alternator to the back if you're going to run one.Cary Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166359 Share on other sites More sharing options...
May 6, 200618 yr comment_166360 I'd move the alternator to the back if you're going to run one.How do you move the alternator to the back? What drives it? Link to comment https://www.classiczcars.com/forums/topic/19915-autocross-fuel-cell-install/#findComment-166360 Share on other sites More sharing options...
