Posted May 6, 200618 yr comment_166419 I am getting a "buzzing " noise from the shifter of my 79 ZX. I know I'm probably getting close to needing tranny work with 179K on the clock. BUT, I wonder what specifically this might be. Bearings? Synchros?The noise occurs when gears are engaed. It is the original early 5 speed. I have had a whirring noise like a throw out bearing when I engage the clutch out of gear for some time. Not super loud though. Anyway I recall and article in the Q and A section of road and track back in the 90's where the editor mentioned a problem with the early 5 speeds that could be cured with a simple tightening of a bolt. Anyone recall what this could be??? Link to comment https://www.classiczcars.com/forums/topic/19938-buzzing-noise-from-shifter/ Share on other sites More sharing options...
May 6, 200618 yr comment_166426 Hi deadflo, sounds like exactly the same noise that was annoying me for ages, I had a walnut shifter knob, the threaded nut inside the knob was loose and it was the vibration that was causing the noise. Easily fixed, new knob! Worth a try.... Link to comment https://www.classiczcars.com/forums/topic/19938-buzzing-noise-from-shifter/#findComment-166426 Share on other sites More sharing options...
May 6, 200618 yr Author comment_166428 Wow, I also have a walnut shift knob!I will put the original knob back on and see what happens!I would do that today but I washed the car this monring and now there is a big dusty wind storm. Link to comment https://www.classiczcars.com/forums/topic/19938-buzzing-noise-from-shifter/#findComment-166428 Share on other sites More sharing options...
May 7, 200618 yr comment_166436 Yeah, actually my brother had the same problem with his shifter - was a dodgy gearknob! Hopefully that's the answer - would be nice and easy Link to comment https://www.classiczcars.com/forums/topic/19938-buzzing-noise-from-shifter/#findComment-166436 Share on other sites More sharing options...
May 7, 200618 yr Author comment_166441 Thanks, mates! Guess what? I switched out the shifter knob tonight and took a spin on the country roads around my house.Problem solved!! No noise at all!I'll take a look at the walnut shifter knob to see if I can do something with it to stop the noise... Link to comment https://www.classiczcars.com/forums/topic/19938-buzzing-noise-from-shifter/#findComment-166441 Share on other sites More sharing options...
May 7, 200618 yr comment_166457 Try putting a little dab of silicon seal on the first threads on the shift lever, then put the knob back on. I did this with a leather shift knob that exibited the same buzzing symptom and the annoying buzz went away.Mike Link to comment https://www.classiczcars.com/forums/topic/19938-buzzing-noise-from-shifter/#findComment-166457 Share on other sites More sharing options...
