Posted May 10, 200618 yr comment_167018 Going to buy a numbers matching Series I build date 3/70 today. Pretty complete with minimal rust, $700.00. It needs the drivers front fender replaced and a little work on the frame where the bumper bolts in but it looks to be pretty solid. One small hole in passengers floor pan at the rear of frame rail, and the drivers wheel arch looks to be full of bondo. Overall it is in decent shape, I hope to be able to drive it for a while before I start work on my 73’.I will post some pics tonight when I get home. Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/ Share on other sites More sharing options...
May 10, 200618 yr comment_167026 Good luck! Make sure you post your car with Carl Beck's regisrty. Look forward to pictures. What are your plans with it? Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167026 Share on other sites More sharing options...
May 10, 200618 yr comment_167031 Going to but a numbers matching Series I build date 3/70 today. Pretty complete with minimal rust, $700.00. It needs the drivers front fender replaced and a little work on the frame where the bumper bolts in but it looks to be pretty solid. One small hole in passengers floor pan at the rear of frame rail, and the drivers wheel arch looks to be full of bondo. Overall it is in decent shape, I hope to be able to drive it for a while before I start work on my 73’.I will post some pics tonight when I get home.Oh sure, rub it in-seriously, great find and congratulations!Will Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167031 Share on other sites More sharing options...
May 10, 200618 yr comment_167034 Good luck! Make sure you post your car with Carl Beck's regisrty. Look forward to pictures. What are your plans with it?You know, I've tried to get my car registered on Carl's registry several different times since I bought it last September. Nothing ever happens. Similarly I've tried several times to join the IZCC, and that never works either. So if you are able to get your car registered, let me know how you did it. Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167034 Share on other sites More sharing options...
May 10, 200618 yr comment_167035 You know, I've tried to get my car registered on Carl's registry several different times since I bought it last September. Nothing ever happens. Similarly I've tried several times to join the IZCC, and that never works either. So if you are able to get your car registered, let me know how you did it.+1. I tried sometime ago and I didnt have any luck either. Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167035 Share on other sites More sharing options...
May 10, 200618 yr comment_167039 Huh?! Did you write to him and bitch him out? This is how you subscribe to IZCC. There isn't anything to join. Subscribe to this and you get a ton of e-mails every day.Z-Car List InstructionsTo Subscribe:Send an e-mail message to:Majordomo@taex001.tamu.eduIn the body of the message (leave the subject line blank) put:"subscribe z-car"without the (") quotes, a space and your e-mail address.For example:subscribe z-car jhill@atlantic.netand/orAnother option is to subscribe to the "digest" form of the list - instead of 60individual posts per day - they are pooled up and sent within a single messageaprox. 20 at a time, this cuts down a lot on the traffic...subscribe z-car-digest (your email address) Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167039 Share on other sites More sharing options...
May 10, 200618 yr comment_167040 Tried to sign up with IZCC here:http://www.mlinks.net/~aktar/memberdb/entry/As far as bitching Carl out, nope, not my style. He and I have corresponded on other stuff a bit, and I did mention once that I couldn't get my car registered, and he gave me a tip to try, but that didn't work either. In the big picture, it's not worth getting mad or worked up about. But if someone can get it to work, I'd like to get it done. Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167040 Share on other sites More sharing options...
May 10, 200618 yr comment_167043 Huh?! Did you write to him and bitch him out? This is how you subscribe to IZCC.I don't know that anyone here is talking about subscribing to an e-mail list. The discussion is about adding our cars to the Registry which should simply be done by filling out an online form here:http://zhome.com/IZCC/ZRegisters/#ClassicI know I've tried a couple of times in the past as well. Perhaps there's a problem with the software.EDIT: Sorry Chris, I see now that Arne was trying to sign up for both the e-mail list and the registry. Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167043 Share on other sites More sharing options...
May 10, 200618 yr comment_167046 Tried to sign up with IZCC here:http://www.mlinks.net/~aktar/memberdb/entry/As far as bitching Carl out, nope, not my style. He and I have corresponded on other stuff a bit, and I did mention once that I couldn't get my car registered, and he gave me a tip to try, but that didn't work either. In the big picture, it's not worth getting mad or worked up about. But if someone can get it to work, I'd like to get it done. VIN:HLS30 012746 Production Date:10 / 70 Color Body /Int :919 Yellow/ Black Orig.Eng.Number:L24 16254 Owner:Arne Berglund City/State/Cntry:Springfield, OR IZCC Member#: Comments:A/T converted to 4spd. e-mail:e21graymarket%40comcast.net Date Registered:07 May 06 <a href=http://zhome.com/IZCC/ZRegisters/classic.htm TARGET=NEW>http://zhome.com/IZCC/ZRegisters/classic.htm</a>first submitted 23 Nov 05 - missing original engine numbersecond submit - 17 Mar. 06 - OKthird submit - 07 May 06 - OkWhy the delay between March and May.... da.. I somehow missed it on the update in April...sorry...With over 15,000 members in the IZCC - and about 200 e-mail messages per day (it seems that way anyway).. I do get behind at times and things can drop thru the crack... If they do.. just e-mail and let me know.. no problemFWIW,Carl Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167046 Share on other sites More sharing options...
May 10, 200618 yr comment_167048 Tried to sign up with IZCC here:http://www.mlinks.net/~aktar/memberdb/entry/Web Forms some times get screw up in transmission or sometimes for some reason the just don't transmit at all...You can contact our Membership Chairman directly..via e-mail:"Tony Fruzza" aktar@cosanostra.netthanks,Carl Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167048 Share on other sites More sharing options...
May 10, 200618 yr comment_167049 VIN:HLS30 012746 Production Date:10 / 70 Color Body /Int :919 Yellow/ Black Orig.Eng.Number:L24 16254 Owner:Arne Berglund City/State/Cntry:Springfield, OR IZCC Member#: Comments:A/T converted to 4spd. e-mail:e21graymarket%40comcast.net Date Registered:07 May 06 <a href=http://zhome.com/IZCC/ZRegisters/classic.htm TARGET=NEW>http://zhome.com/IZCC/ZRegisters/classic.htm</a>first submitted 23 Nov 05 - missing original engine numbersecond submit - 17 Mar. 06 - OKthird submit - 07 May 06 - OkWhy the delay between March and May.... da.. I somehow missed it on the update in April...sorry...With over 15,000 members in the IZCC - and about 200 e-mail messages per day (it seems that way anyway).. I do get behind at times and things can drop thru the crack... If they do.. just e-mail and let me know.. no problemFWIW,CarlSee? That's why it doesn't pay to get upset. I don't sweat the little things in life. Thanks for the update, Carl. I hadn't looked since the May 7 submission. My bad. Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167049 Share on other sites More sharing options...
May 10, 200618 yr comment_167050 Web Forms some times get screw up in transmission or sometimes for some reason the just don't transmit at all...You can contact our Membership Chairman directly..via e-mail:"Tony Fruzza" aktar@cosanostra.netthanks,CarlI e-mailed Tony last week, too soon to expect anything on this yet. I'm sure that Tony gets piles of mail too. Link to comment https://www.classiczcars.com/forums/topic/20000-numbers-matching-series-i-early-1970/#findComment-167050 Share on other sites More sharing options...
