Numbers matching Series I early 1970
Thanks for all the replies!
I got the hatch open tonight by removing the hatch panel and pressing the latch down. I then pulled the lock out so I can take it and get a key made for it and the ignition.
Under the deck lid I found nice paint, no rust decent aftermarket carpet (72/73 style) and complete luggage straps. The spare tire well is fresh and shiny and I even got the spare tire hold down and a decent cover board.
I am stoked!:D
The seat belts are complete and correct and just need to be cleaned up it looks like and the console is not broken from the looks.
Now if I could only find a complete Series I dash.
I also got the gauges working tonight (missing fuse). I don't think the clock works though (go figure right!).LOL
Thinking of pulling the brakes apart this weekend to see what is the matter there so I can try to get it on the road.
just wondering, but what is or how do you tell a series I dash from a series II
Dash? I always thought the series I had the blank plug where the lighter
goes in the series II?
I should have been more specific, my car has the later Series 1 dash with the indentation for the hazard switch label and the blank spot for the fog lamp switch.
I believe it should have the dash without the label indentation but with the blank spot, as it is an early 70' model. Anyone can step in and correct me if I am wrong, please.
Hi Guys:
Series I - built 10/69 and into early 01/71 Vents on Rear Deck
Series II - built 01/71 and into 08/71 Vents moved to side of car
Series III - the 1972 Model year Z's.. 08/71 - 08/72 type B tranny, flip forward seats etc
Series IV - the 1973 Model year Z's... emissions carbs... 08/72 - 08/73
Dash:
Series I and II had the same dash - with no indent for the flasher decal/sticker
Series III - indent for flasher decal/sticker & cig. lighter moved to dash
Series IV - larger opening for lighted, pull type hazzard warning switch
FWIW,
Carl
Carl Beck
Clearwater, FL USA
http://ZHome.com
Hi Guys:
Dash:
FWIW,
Carl
Carl Beck
Clearwater, FL USA
http://ZHome.com
Ahhhhhh I see..thanks Carl..
ohh by the way, I sent in my car info for the registry sometime back in the
early to mid 90's.....but somehow the info never got to you :P
Im IZCC # 346 by the way..
Eric,
The dash is cracked - just send it out and have it recovered without the indent. http://www.dashboardrestorations.com.au/index.htm I think your gear shift boot is the correct one with the rubber ring instead of the leather lace. Your chromed center vent looks good and so does the map light.
Nice find!
Thanks man!
I never thought of that, aside from the indent the dashes are the same. I will look into it when the time comes.
I am really happy with the overall condition of the car and for $700.00 I couln't pass it up.
Thank god for Craigs List!
Well I am off to work, thank again for the replies.
Eric
I see an update to your Membership Data in 99... but nothing on the cars.
This would be a good time to send it again..You can send it directly to me at beck@becksystems.com
For Each Car the following must be complete
VIN:
Build Date: (from the Drivers Door Jam)
Original Color: (Ext/Int) and current color if different:
Original Engine Serial Number: (from the Data Tag under the hood)
Name:
City/State
e-mail
Comments:
IZCC Membership #346
Public Register Yes/No?
