in a nutshell, pull everything connected to the engine via the engine harness, you will use the complete setup. Buy a running donor, and the ods are you won't need anything else other than a 2" hole saw, and some plumbing to adapt the non injection gas tank to the new to the car.
You will need the fuel pump, ecm, engine harness, AFM, fuel pump relay.
With a running donor, move everything that the engine requires to run.
As I said, there are several writeups on the web that give you what you are asking for-the engine by its self ain't gonna do it. If you don't get everything else, you will have to replace the systems you left out, and that will add complexity to getting it running..
Will
https://www.classiczcars.com/forums/topic/20005-btw/#findComment-167343
