Posted May 11, 200618 yr comment_167097 in the project i am going to attempt ...i wanna know what am i gonna need an order to put a l28et into a 240z...i have a l28 wiring harnes ...can i use that for the l28...i wanna know EXACLTY what i need Link to comment https://www.classiczcars.com/forums/topic/20005-btw/ Share on other sites More sharing options...
May 11, 200618 yr comment_167100 Hybrid Z has a couple of tech articles on the swap, and there are others on the web too. It isn't a hard thing to do-pretty much a motivated weekend if you have all of the right parts, tools and properly chilled liquid refreshment!!Will Link to comment https://www.classiczcars.com/forums/topic/20005-btw/#findComment-167100 Share on other sites More sharing options...
May 11, 200618 yr Author comment_167175 k thanks.........and will i have to modify the whole wiring harness or i can just use the turbo one? Link to comment https://www.classiczcars.com/forums/topic/20005-btw/#findComment-167175 Share on other sites More sharing options...
May 12, 200618 yr Author comment_167341 mainly i just wanna know what am i gonna exaclty need...i allready founf the engine...but i wanna know what exactly am i gonna need it would really help thanks! Link to comment https://www.classiczcars.com/forums/topic/20005-btw/#findComment-167341 Share on other sites More sharing options...
May 12, 200618 yr comment_167343 in a nutshell, pull everything connected to the engine via the engine harness, you will use the complete setup. Buy a running donor, and the ods are you won't need anything else other than a 2" hole saw, and some plumbing to adapt the non injection gas tank to the new to the car.You will need the fuel pump, ecm, engine harness, AFM, fuel pump relay.With a running donor, move everything that the engine requires to run.As I said, there are several writeups on the web that give you what you are asking for-the engine by its self ain't gonna do it. If you don't get everything else, you will have to replace the systems you left out, and that will add complexity to getting it running..Will Link to comment https://www.classiczcars.com/forums/topic/20005-btw/#findComment-167343 Share on other sites More sharing options...
May 13, 200618 yr comment_167399 I think this is the link you're looking for...http://forums.hybridz.org/showthread.php?t=104196&highlight=n%2Fa+turboyou need to know how much RWHP you want ... that will help you deside what you do and dont need for the turbo swap into your 240. good luck Link to comment https://www.classiczcars.com/forums/topic/20005-btw/#findComment-167399 Share on other sites More sharing options...
May 15, 200618 yr Author comment_167544 answer me this: could i use some relays from the n/a 280zx for a turbo engine? Link to comment https://www.classiczcars.com/forums/topic/20005-btw/#findComment-167544 Share on other sites More sharing options...
