Posted May 21, 200618 yr comment_168167 im new to the zcar world i just bought my 78 black pearl im needing a set of mirrors and a stripe kit i also need to know did all black pearls have hood vents and were they functional or just attached to a stock hood thanks Link to comment https://www.classiczcars.com/forums/topic/20119-hi-need-help/ Share on other sites More sharing options...
May 21, 200618 yr comment_168171 All 77-78 280Zs came with hood vents and a hood designed for them. They are functional in that they do let air (and anything else) in. The mirrors you can find but I don't think the stripe kit is available any longer. Link to comment https://www.classiczcars.com/forums/topic/20119-hi-need-help/#findComment-168171 Share on other sites More sharing options...
May 21, 200618 yr comment_168175 What style mirrors are you looking for? Motorsport Auto which specializes in Z's has a few different kinds to choose from. http://www.thezstore.com/store/merchant.mvc?Screen=CTGY&Category_Code=OM For your question on the vents- Yes, the hood vents were on the Z's factory on the 1977-1978 280Z's. Were they functional? You better believe it They helped tremendously to allow the heat from the engine to escape. Anyway, welcome aboard to the wonderful world of Z's. It's like they used to say in there commercials "Once you get inside a Z, the Z get's inside you" :D Looks like Stephen beat me to the hood vent answer Link to comment https://www.classiczcars.com/forums/topic/20119-hi-need-help/#findComment-168175 Share on other sites More sharing options...
May 21, 200618 yr Author comment_168182 thanks for the info the mirrors i need are the stock units that came on the 78 BPs Link to comment https://www.classiczcars.com/forums/topic/20119-hi-need-help/#findComment-168182 Share on other sites More sharing options...
May 21, 200618 yr comment_168220 You're looking for '99990-00113' but they aren't available from the dealer anymore. The ones that MSA sell are similar but not the same. Ebay? Link to comment https://www.classiczcars.com/forums/topic/20119-hi-need-help/#findComment-168220 Share on other sites More sharing options...
May 21, 200618 yr comment_168241 Avoid the replica mirrors. They look good for a while, but over time they loosen up and don't hold thier adjustment. They'll flop all over with bumbs and vibrations. You can see them in my gallery if you want, but I wouldn't buy them. Link to comment https://www.classiczcars.com/forums/topic/20119-hi-need-help/#findComment-168241 Share on other sites More sharing options...
May 21, 200618 yr comment_168264 I bought a set of mirros from MSA, and the local Autozone, et al, hadthe samething for 1/3 the price. You probably need to make sure that you get the exact same one that were on there. Link to comment https://www.classiczcars.com/forums/topic/20119-hi-need-help/#findComment-168264 Share on other sites More sharing options...
May 21, 200618 yr comment_168278 A Set of NOS Nissan supplied Racing Mirrors - as used on the Black Pearl's just sold on e-bay for $405.00. See Item Number 8065716766You can find them in used condition at very reasonable prices.On a Black Pearl you really should have the correct mirrors if you want to keep the Stock Look.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/20119-hi-need-help/#findComment-168278 Share on other sites More sharing options...
May 22, 200618 yr comment_168299 I agree the stock mirrors would be best. I just mentioned the ones from MSA incase you needed an alternative. Virto, the mirrors on your Z look fine to me. Don't trash them because the problem can be solved by simply tightening the two screws behind the mirror glass. Make sure you do that soon because if they are loose, they will only get looser with bumps/vibration and the head of the mirror will fall off eventually. :paranoid: Link to comment https://www.classiczcars.com/forums/topic/20119-hi-need-help/#findComment-168299 Share on other sites More sharing options...
