Car not starting after SU swap on 74 260z, Pictures!
xxjoeyxxeb
Hey guys, car wont start after the SU swap. No fuel getting to the fual lines going into carbs. Haven't tried using starter fluid yet, and battery has been losing its power, so gotta get some starte fluid and a battery charger.
Heres a link to page 4 with some pictures from all angles, http://www.cardomain.com/ride/2228239/4 let me know how it looks, and if I messed anything up. Also, last pic has a hose that runs with the fuel lines and looks like it might end at the carbon canister, anyone plug this up or do away with the whole line?
Has your fuel pump died? or fuel filter blocked? Take the outlet hose off the pump and crank the car over. fuel should come out. Then check it along the fuel rail. Take it off at the carbies and see if its coming out there. Also this line going to the carbon canister. Is it connected to the fuel line? Because i dont think it should be.
That line on the last picture is a Canister Purge Line. Found that out in the Haynes manual page 68 figure 3.76 number 8. Why am I the only on with it there?
Most of us have earlier 240Zs. The hoses for the 260Z and '73 240Z are much different.
