Hi Mperdue-
I don't know what the difference is between the two. Your probably correct in assuming differences in thickness based on wheel size as the geometry will differ between the two sizes. The only thing I can suggest is to call MSA and ask them what the differences are and if one of the spacers is more universal. My guess is you will need to know what size wheel you'll run before you order. Maybe you could post this information once you get it. I didn't bother asking because I knew I would go to a 15" wheel.
My understanding is that bump-steer is a problem in stock Z’s and lowering the
car, especially more than 1 inch, makes it worse. Installing spacers corrects
for the roll-center change, but does nothing for the inherent bump-steer problem.
The only thing that does correct bump-steer is to relocate the front lower control
arm to cross-member connecting point..
The following is from the “Jags That Run”V8 conversion manual:
Remove the front cross-member, remove the doublers that are spot welded to the
cross-member. Weld .060” thick steel doublers inside the cross-member, drill
14mm (9/16”) holes ¾” (center to center) above the original holes (and ¼” outward
if you want o add negative camber). Weld the original holes shut, grind flush and
re-paint. The upper inboard corners of the lower control arms will have to be grinded
to prevent them from contacting the cross-member.
Is all this for really aggressive driving? I'm putting the unadjustable tokicos in too along with urethane bushings and wondering if I should start messing with suspension like this? I drive hard, but not racing hard. The car is just a daily driver.
Originally posted by ecp48
Zed,
Is it possible to get a copy of the page which deals with the cross member mods.......
Sorry, I don't have a scanner, but this link that mperdue posted covers it pretty good.
http://240z.jeromio.com/frontcross.html
Originally posted by zed240au
hi zed
Have you actually done the Jags that Run mod have read of it but never heard of anyone doing it would like to here from anyone who has and if it really works
Ragards Mick
Sorry, I haven't done it yet, I'm just passing on what I've read. I'm not to that point in my restoration / modification yet.
Below is a pic from the JTR manual that shows the lower control arm modification that is not shown at http://240z.jeromio.com/frontcross.html
I took it with a digi camera, so the quality isn't all that great.
On my lowered racecar, WITH the spacers between the strut and the balljoint, the 14x7 Slotted mag WILL rub on the tie rod end hard enough to prevent the car from rolling! The previous owner installed about 3/8th" spacer plates between the wheel and the hub on each side to space the wheels out far enough to prevent the contact. I don't like this set up so I will be moving to 15" wheels when I auto-x or race.
Eric aka ZMunkey
