May 30, 200618 yr Author comment_169293 Hello Ed Thanks for the reply. I borrowed this picture from another thread here on the website; are these the locations of the grease fittings which you are referring to? Thanks Joseph Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-169293 Share on other sites More sharing options...
May 31, 200618 yr comment_169411 Joseph, You hit it with that picture. The Zerk fitting on the pinion, was not familiar, but the one on the other end, was just what I remember. I've been meaning to find an early rack to install in my current 280Z (78), but just haven't had time. Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-169411 Share on other sites More sharing options...
June 5, 200618 yr Author comment_170001 Hey Ed/All Based on the info supplied in this thread through the replies I managed to do some 'trouble-shooting' over the weekend to identify the rack in the car. I have identified it as a later style, 260-Z rack. I have based this on not being able to find a grease fitting of any kind on the non-pinion end of the rack, not hidden by the boots and also the fact that the pinion box section appears to be steel rather than aluminium, ie a magnet will stick to it. I got some pics through from a friend here in Australia with both a 240-Z and a 260-Z. The 260-Z rack also has some kind of inspection plate/cover on the rack where the pinion shaft attaches to the splines whereas the 240-Z rack does not. I will post the pics here for future reference. Rack mounting bushing measurements would be nice at this stage. So, I need to find a genuine RHD 240-Z steering rack here in Australia. Is there anyone whom may have one available? Thanks again for the help on this one to date. Joseph Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-170001 Share on other sites More sharing options...
June 5, 200618 yr comment_170013 Joseph, I have both racks available, the one on the top is 260Z & the bottom one is 240Z. (see pics below). Notice the narrower bush (35mm for the 260Z & 29mm for the 240Z)... the 240Z one also has both zerk fittings so I'm guessing this is the type you're after? Nick. Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-170013 Share on other sites More sharing options...
October 2, 200618 yr comment_184420 Sorry to post on an old thread, but I have an early 240 rack which I'd like to rebuild. From what I've read being an early rack, this is fairly easlily accomplished. Rather than search forever for part numbers, does anyone have a complete list? Does Nissan stock a "kit", or do I need to order everything piece by piece?I've also read it's cheaper and easier to source a rebuilt one, but this is for my road racer. I won't be using the factory inner tie rods (the expensive part), but rather modifying it for heim joints, or rod ends. Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-184420 Share on other sites More sharing options...
October 3, 200618 yr comment_184561 I asked MSA about rebuilt racks. They informed me that rebuilt racks are no longer available as the inner bushing, which is the primary source of "failure", is no longer made.There is a thread here (or on Zcar.com) that talks about rotating the bushing 180 degrees. It is my recollection that the bottom part of the bushing wears out first. Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-184561 Share on other sites More sharing options...
October 4, 200618 yr comment_184627 The 180 trick sounds interesting. I assumed Victoria British didn't have anything, but after posting this I checked their catalog and they do in fact list the bushings and seals. Their parts brands seem to be hit or miss lately, but I'll probably order through them. Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-184627 Share on other sites More sharing options...
October 4, 200618 yr comment_184637 Quick questions for those still confused mainly myself.1.) Is a Zerk Fitting the same as a Grease Nipple?2.) The difference between late rack (260z, 280z) and early rack (240z) is that the early rack has two Zerk fittings allowing it to last longer due to more/better lubrication?This is interesting and contradicting to what I have read previously that the later 260z rack was more robust and therefore better in design. Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-184637 Share on other sites More sharing options...
October 4, 200618 yr comment_184688 Gavin,You have the right idea. a Zerc is a grease nipple. As long as you keep the early one lubed, it seem to continue to last. The later 260/280 can goi in as little as 3-4 years. Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-184688 Share on other sites More sharing options...
October 5, 200618 yr comment_184763 How are you suposed to know if your rack is shot? My stearing has about a quarter inch play before it engages the wheels. And yes I did replace my rack mounts with new urathane, so I know that the rack isn't moving. Does the pinion go bad, or is it the bushings or does the rack gear spacing get to big. Thanks Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-184763 Share on other sites More sharing options...
October 5, 200618 yr comment_184771 You might try here http://www.buy-steering.com/ the guy on the phone said it was no problem to get early racks.Best, H Houghton Link to comment https://www.classiczcars.com/forums/topic/20171-steering-rack-differences-240-z-vs-260-z-280-z/?&page=2#findComment-184771 Share on other sites More sharing options...
