I've done this and its not that hard of an operation, the only problem I had was getting the fan out from inbetween the motor and the fan shroud. You may not need to take the fan out though, I only took it out to check out the fan clutch. Good Luck =)
Be careful when you take out the bolts because if they break off in the block, like one did for me, you gotta take off the timing cover to remove it. Oh yeah and if this does happens don't use an "easy out" tool because if it breaks off, like it did for me:stupid: , it's a pain in the arse to get it out. Other than that it's an easy job, one day tops
