blue_leaf Posted June 1, 2006 Share #1 Posted June 1, 2006 Considering using s12w calipers and z31 rotors, want to know where to buy the required spacers for use on 72 240z. I know this has been covered before, but I need up to date infromation. Thanks in advance. Link to comment Share on other sites More sharing options...
loy Posted June 1, 2006 Share #2 Posted June 1, 2006 http://www.modern-motorsports.com/catalog/product_info.php?manufacturers_id=&products_id=48 Link to comment Share on other sites More sharing options...
hls30.com Posted June 1, 2006 Share #3 Posted June 1, 2006 I picked mine up on ebay. Seems like they were $62 a pair.I'll see if I can find the particulars over the next few days.Will Link to comment Share on other sites More sharing options...
Dtsnlvrs Posted June 2, 2006 Share #4 Posted June 2, 2006 FWIW: You can also use the s12+8 caliper from the 1986 (only 1986) Toyota 4x4 PU. Use the same spacer for the s12w, Ross @ www.modernmotorsports.com has them, and the same 84-85 NA Z31 rotor. This gives you a 4piston setup, albiet smaller secondary piston, but weighs a little less and is more than effective. BTW the 86 toy 4x4 caliper is cheaper including core charge than the later ones if cost is a concern, and Axxis Metal Master pads are available for this caliper. Link to comment Share on other sites More sharing options...
blue_leaf Posted June 3, 2006 Author Share #5 Posted June 3, 2006 I picked mine up on ebay. Seems like they were $62 a pair.I'll see if I can find the particulars over the next few days.WillCould you please tell me the e-bay id of the seller? Link to comment Share on other sites More sharing options...
hls30.com Posted June 3, 2006 Share #6 Posted June 3, 2006 The sellers ebay name is JSKinovations.Will Link to comment Share on other sites More sharing options...
blue_leaf Posted June 3, 2006 Author Share #7 Posted June 3, 2006 The sellers ebay name is JSKinovations.WillThanks Will Link to comment Share on other sites More sharing options...
dat260 Posted June 3, 2006 Share #8 Posted June 3, 2006 HiJSK is out of the Z business. Check this guy from Ebay.http://stores.ebay.com/PAULS-FAB-AND-PERFORMANCE_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkmCheers, Link to comment Share on other sites More sharing options...
