Posted June 1, 200618 yr comment_169471 Considering using s12w calipers and z31 rotors, want to know where to buy the required spacers for use on 72 240z. I know this has been covered before, but I need up to date infromation. Thanks in advance. Link to comment https://www.classiczcars.com/forums/topic/20248-spacer-for-use-of-s12w-where-to-buy-and-how-much/ Share on other sites More sharing options...
June 1, 200618 yr comment_169547 http://www.modern-motorsports.com/catalog/product_info.php?manufacturers_id=&products_id=48 Link to comment https://www.classiczcars.com/forums/topic/20248-spacer-for-use-of-s12w-where-to-buy-and-how-much/#findComment-169547 Share on other sites More sharing options...
June 1, 200618 yr comment_169549 I picked mine up on ebay. Seems like they were $62 a pair.I'll see if I can find the particulars over the next few days.Will Link to comment https://www.classiczcars.com/forums/topic/20248-spacer-for-use-of-s12w-where-to-buy-and-how-much/#findComment-169549 Share on other sites More sharing options...
June 2, 200618 yr comment_169594 FWIW: You can also use the s12+8 caliper from the 1986 (only 1986) Toyota 4x4 PU. Use the same spacer for the s12w, Ross @ www.modernmotorsports.com has them, and the same 84-85 NA Z31 rotor. This gives you a 4piston setup, albiet smaller secondary piston, but weighs a little less and is more than effective. BTW the 86 toy 4x4 caliper is cheaper including core charge than the later ones if cost is a concern, and Axxis Metal Master pads are available for this caliper. Link to comment https://www.classiczcars.com/forums/topic/20248-spacer-for-use-of-s12w-where-to-buy-and-how-much/#findComment-169594 Share on other sites More sharing options...
June 3, 200618 yr Author comment_169781 I picked mine up on ebay. Seems like they were $62 a pair.I'll see if I can find the particulars over the next few days.WillCould you please tell me the e-bay id of the seller? Link to comment https://www.classiczcars.com/forums/topic/20248-spacer-for-use-of-s12w-where-to-buy-and-how-much/#findComment-169781 Share on other sites More sharing options...
June 3, 200618 yr comment_169791 The sellers ebay name is JSKinovations.Will Link to comment https://www.classiczcars.com/forums/topic/20248-spacer-for-use-of-s12w-where-to-buy-and-how-much/#findComment-169791 Share on other sites More sharing options...
June 3, 200618 yr Author comment_169793 The sellers ebay name is JSKinovations.WillThanks Will Link to comment https://www.classiczcars.com/forums/topic/20248-spacer-for-use-of-s12w-where-to-buy-and-how-much/#findComment-169793 Share on other sites More sharing options...
June 3, 200618 yr comment_169794 HiJSK is out of the Z business. Check this guy from Ebay.http://stores.ebay.com/PAULS-FAB-AND-PERFORMANCE_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkmCheers, Link to comment https://www.classiczcars.com/forums/topic/20248-spacer-for-use-of-s12w-where-to-buy-and-how-much/#findComment-169794 Share on other sites More sharing options...
