Posted June 1, 200618 yr comment_169542 I am a neophyte regarding Z engines. Do most Z engines use solid or hydraulic valve lifters? I have driven 3 Z cars in my search for a good Z car and all have had a lot of valve tappet noise. Is this normal or do the valves need to be adjusted (if they are solid lifters)?? Would they need adjustment if they were hydraulic lifters? Thanks Widget777@centurytel.net Link to comment https://www.classiczcars.com/forums/topic/20259-valve-lifters-for-280z/ Share on other sites More sharing options...
June 1, 200618 yr comment_169544 All Z heads except one have no lifters, the rocker arm drives directly against the camshaft. The one head that has hydralic lifters is the P-90A and I believe would only be found in a 280ZX unless an earlier car was retrofitted with one.Valve adjustment is a normal maintance item on a Z engine and so the noise you are hearing can be considered normal and that the cars just need an overall tune up more than likely. Link to comment https://www.classiczcars.com/forums/topic/20259-valve-lifters-for-280z/#findComment-169544 Share on other sites More sharing options...
June 1, 200618 yr comment_169555 Lance is correct . The P-90a is a head on a turbo engine . the P-90 is also on a turbo but it isn't hydraulic Link to comment https://www.classiczcars.com/forums/topic/20259-valve-lifters-for-280z/#findComment-169555 Share on other sites More sharing options...
June 2, 200618 yr Author comment_169561 Thanks for your input. I guess that is why there is OHC cast into the valve cover???? I should have thought about this before I asked. thanks for your patience. Link to comment https://www.classiczcars.com/forums/topic/20259-valve-lifters-for-280z/#findComment-169561 Share on other sites More sharing options...
June 2, 200618 yr Author comment_169562 Thanks for your input. I guess that is why there is OHC cast into the valve cover???? I should have thought about this before I asked. thanks for your patience.__________________ Link to comment https://www.classiczcars.com/forums/topic/20259-valve-lifters-for-280z/#findComment-169562 Share on other sites More sharing options...
June 2, 200618 yr comment_169564 As the government man would say, "we're here to help." Link to comment https://www.classiczcars.com/forums/topic/20259-valve-lifters-for-280z/#findComment-169564 Share on other sites More sharing options...
June 2, 200618 yr comment_169607 Widget777, I see you are in Gig Harbor. If you have any tech or mechanic needs, see Doug @ Fairlady Motors in Tacoma. www.fairladymotors.com Tell him Russell from the Army sent you. BTW he may be able to help you find a good Z. Shoot, he may have one to sell you....dont really know what he is up to these days, have not seen him in about a year. Link to comment https://www.classiczcars.com/forums/topic/20259-valve-lifters-for-280z/#findComment-169607 Share on other sites More sharing options...
June 2, 200618 yr comment_169628 OHC = Over Head Cam, which is different than your typical 1970 car which had pushrods instead, just clarifying. Link to comment https://www.classiczcars.com/forums/topic/20259-valve-lifters-for-280z/#findComment-169628 Share on other sites More sharing options...
