Posted June 3, 200618 yr comment_169829 I can't remember when I removed the suspension 'stuff' if there was a gap between the ball joint and the transverse link. There was so much grease and dirt to clean out. Either way, the joint doesn't sit flush with the t-link but all of the nuts/bolts are flush with everything. See pic... Link to comment https://www.classiczcars.com/forums/topic/20283-ball-joint-gap/ Share on other sites More sharing options...
June 3, 200618 yr comment_169831 there should be a gap, but not sure how big it should be, if you want just give me some time and I'll reply to u with a photo of mine (if possible) since the car is jacked for the comp. rod;)maybe your ball joint is not original?? Link to comment https://www.classiczcars.com/forums/topic/20283-ball-joint-gap/#findComment-169831 Share on other sites More sharing options...
June 3, 200618 yr Author comment_169833 They're moog replacements. I think there was a gap when I took the old one's out, just don't remember... Link to comment https://www.classiczcars.com/forums/topic/20283-ball-joint-gap/#findComment-169833 Share on other sites More sharing options...
