hey i have a book on it. if you are refering to the 2 aluminum or steel, 0.5" thick, then they are supossed to go between the front crossmember and the car body(frame rails). they lower the front crossmember (engine) 0.5" it allows for the engine to be in the setback position. hope that helps
Recently Browsing 0
