i have the JTR motor mount kit.. it didnt come with any instructions i was wondering if anyone who has done it can help me PLEASE!!!!!....which spacers go where??? pictures if possbile thankz
https://www.classiczcars.com/forums/topic/20320-v8-conversion-help-pleasee/
as per my short experience, guys on www.hybridz.org are good at it (I dont mean that our guys are not good) but people here are mostly a "classiczcars" fans..
I hope that u get the answer soon..
cheerz
hey i have a book on it. if you are refering to the 2 aluminum or steel, 0.5" thick, then they are supossed to go between the front crossmember and the car body(frame rails). they lower the front crossmember (engine) 0.5" it allows for the engine to be in the setback position. hope that helps
The JTR manual is almost a must for a V8 swap. There's tons of good info there.
So far as the mounts, the setback plates bolt to the block, and the spacers go between the mounts and the plates. The thicker spacer goes on the drivers side.
jt
