Posted June 7, 200618 yr comment_170254 Hi everyone, I'm looking at getting a set of 260z 2+2 stub axles for my 240z.I'm wondering if the 2 seater and 4 seater stub axles are the same? I imagine the only difference is that the 2+2's had longer driveshafts but the same stub axles.In the US I understand you guys swap to 280z stub axles which are the same as 260z stub axles here in Australia as far as I'm aware.If anyone has anymore details let me know.Reason for 260z stub axles is that I believe they are stronger and these are easier to adapt to a CV joint upgrade, something I will be doing in the future with an R200 LSD. Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/ Share on other sites More sharing options...
June 7, 200618 yr comment_170284 hi gavin the main differnce in the later 260z or 280z hubs are that they have 27 splines compared to 25 on the 240z or earlier 260z stub axles other wise they look the same i am upgrading to cv shafts and the adaptors i have will weld to either 240z style or later style as theres no difference in the axle flange that bolts to axlesNow im waiting on my second set to be sent to me after being assured the first set where later 260z only to recieve and see there was no difference the guy even told me i didnt know what i was talking about been told since he no longer works for that z shop the boss assures me he sent me the right ones this time so im waiting to seehe did make comment that on the later 260 the should be 4 humps or marks not on the 240 ones my worry is that on my current 240z stubs one has 4 humps and the other doesnt so will wait and seebe just as easy to count the splines i reckon as such the 240z flange should not fit a later 260z stubas for the cv conversion its really only the extra strengh u gain from extra splines mick Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170284 Share on other sites More sharing options...
June 7, 200618 yr Author comment_170285 Hi Mick yes I heard that information as well about the 27 splines. I thought I read it on www.240z.id.au however I could not locate the information when i looked again. Let me know how you go with the stub axles and the differences between 240z and 260z ones when you receive the "correct ones". I'm looking to buy a set of ZKid provided they are the right ones. I also read that early 240z ones have been known to break. pretty scary thought really. Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170285 Share on other sites More sharing options...
June 8, 200618 yr comment_170346 hi gavin well they arrived today the 260 do have 27 splines as well as 4 raised knobs on wheel side flange at least 240 stub has 25 splines flat face to stub axle wheel sidecan email u pic if you want gavin Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170346 Share on other sites More sharing options...
June 8, 200618 yr comment_170350 yeah think the 240 reasonably strong stubs just when u start pumping more hp through they might get stressedits not that enjoyable driving on three wheels on rally i was in with my rx4 we came over a crest about 160 km on gravel next thing im not steering the car back left wheel goes sailing past lucky the mud stopped us 1 foot short of a big tree stump lesson in that not all wheel nuts have the same angle used a set from the guy i bought an rx4 shell off with my mags different angle to the nut and holeThen last weekend im out on my new raptor 4 wheeler and bugger be dead if the left back wheel dont go sailing past got say it was easier to handle than the rx4 on three wheelsso you do want the best nuts and stubs holding your wheels on Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170350 Share on other sites More sharing options...
June 9, 200618 yr comment_170444 zed240auIs it possible to get a copy of the picture which you have offered to Gavin?ThanksJoseph Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170444 Share on other sites More sharing options...
June 9, 200618 yr comment_170492 sure know worries have pm umick Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170492 Share on other sites More sharing options...
June 9, 200618 yr Author comment_170493 Hi Mick,If you could post the image in the thread i'm sure it will help others now and in the future. If that's a hassle please send the pics to gavindoolan at optusnet.com.auThanks alot, Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170493 Share on other sites More sharing options...
June 9, 200618 yr comment_170498 Hello Gav, I think we may be in business, attached is a picture of the spare 240 Legs I have and the 2+2 ones, they have the four bumps on the hub flange. If this is indeed what you are after I shall get dismantling in the not too distant future. Chris Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170498 Share on other sites More sharing options...
June 9, 200618 yr Author comment_170500 Ok I'll await Mick to send the photos of his and hopefully we will be able to confirm. Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170500 Share on other sites More sharing options...
June 11, 200618 yr comment_170699 hi pictures attached pic 1 is the 240z 260z together pic 2 is 240z stub and pic 3 is 260z with bumps mick Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170699 Share on other sites More sharing options...
June 12, 200618 yr comment_170808 Mick/GavinI checked out the stub axles which are in my car over the weekend and it looks like they have been changed out from the original 240-Z to the later 260-Z with the bumps on them.With either of you contemplating the swap from your 240-Z axles to the 260-Z axles, once done, would you have the original 240-Z ones available?What else needs to be changed out to perform this swap? I would need this as well.Thanks for any replies.Joseph Link to comment https://www.classiczcars.com/forums/topic/20325-stub-axle-differences-240z-260z-and-280z/#findComment-170808 Share on other sites More sharing options...
