Your opinion on tires.
justin260z
I would go with a 215/60/14 or a 225/60/14....the 205 is very short for a 14in tire.
Agreed. I have 205/60-14 with a 3.54 rear end, too short geared for a 4 speed. If you don't like the choices in 215/60 or 225/60 (and many don't as the selection isn't very great), better to go with 15 or 16" wheels instead.
Here's a picture of my 280Z with 205-60-14's, the tires are Kelly Platinums. I'm satisfied with the ride, handling and the way it fills up the wheel-well. The springs on the car are stock/OE.
Neither Costco or Discount Tire would let me go oversized on the tires because of the liability issue.
Good luck with your decision.
Well, I've always wanted Falken RT-615 and the only size in 14 is a 195/60. Does anybody have 195/60/14 on their car? My car is for mostly street driving, but I drift on weekends sometimes. I dont have enough money for an extra set of wheels and tires, so I want a good tire for both. Sport Compact Car said the RT-615 is the best street tire they have had yet.
I just put on a set of 195/60/14 tires. They are small but if you like low gearing they are for you. I have an `83 5 speed and a 3.9 diff, with the short tires the gearing is the same as a 4.2:1 with tires 25" in diameter not 23.3". I can still hit 60 in 2nd gear but that is around 7500 rpm. 82 mph occures at 4000rpm in 5th. I like it but my motor is built for that type of gearing, if it was stock it would probably be too short.
BTW the transmission calculator so many of us use has never been close to what my car showing. It says I should be running 3500 rpm at 80 with my setup, pretty far off.
I've got a set of those on 195/60-14s, although I have never used them on the car, it came with them as spares. I run the RT-615 in 205/50-15 though, which is about the same size, and now every other zcar with the correct size looks like they have tank tires on them.
  • Who's Online   2 Members, 0 Anonymous, 417 Guests (See full list)
