First of all, what is the exact size of the holes in the body for placing plastic rivets to hold on the interior panels?
Second, what is a good replacement you use instead of the original plastic pop rivets which are way to expensive. There is an old post about this but maybe there is new info to share.
thanks.
I got some replacement plastic rivets at my local paint supply store. They were far less expensive and have the advantage of using a plastic screw in the center instead of a pin that gets pushed through and lost.
