I've had good luck with mine by simply using some very fine emery cloth as long as the pistons and sleeves aren't too badly pitted or rusted. Try to run the emery cloth around the walls and not up and down. As long as the rubbers can keep a good seal, you will be fine. The $12 rebuild kits from VB work great. Take your time and do a good inspection first.
I don't know of a good site, sorry.
