I think the B.C.D.D. is just hooked into a switch inside the speedo, so disconnecting it & removing it shouldn't affect the way the engine runs- but you have to plug the hole it was from. More wiring diagram research needed. I think you'd probably just get a puff of black out the tailpipe when you let off the gas pedal.
