Posted June 19, 200618 yr comment_171552 Hey all... I have a 72 240 that I am restoring....it is missing all I.D. plates except for engine # and vin #74004....any one aprox. date I,m thinking either march or april 72any help would be great Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/ Share on other sites More sharing options...
June 19, 200618 yr comment_171553 Scan through the registry at zhome.com and look for the closest to your VIN. That should get you in the ball park. Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171553 Share on other sites More sharing options...
June 19, 200618 yr comment_171558 Hi Dan, Member rdefabri here has serial number 73667 with a build date of 3/72. So that should narrow it down a little for you. Sorry I can't be more specific. Chris A. Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171558 Share on other sites More sharing options...
June 19, 200618 yr Author comment_171559 I had a look though there first and could not find anything...unless I missed it somewhere..... the serch continues Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171559 Share on other sites More sharing options...
June 19, 200618 yr Author comment_171561 Oh ya that really helps...found the spot a zhome and looks like 4/72 is about right...or very close... thanks again Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171561 Share on other sites More sharing options...
June 19, 200618 yr comment_171566 Hi Dan:What is the Engine Serial Number?... I'm guessing it's very close too or below L24-95xxxLooks like the car is more likely 03/72. 03 Cars went into the low 75000 range..Carl Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171566 Share on other sites More sharing options...
June 19, 200618 yr comment_171567 My car is HLS30-66434 with a 02/72 build date. Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171567 Share on other sites More sharing options...
June 20, 200618 yr Author comment_171607 the engine serial # is 093518, it is a "completely" rebuilt engine so I am guessing it is not the original....and I figured it had to be a late 3/72 or early 4/72....again thanks for the responses Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171607 Share on other sites More sharing options...
June 20, 200618 yr Author comment_171609 now after rereading Carl's post me thinks it's an original engine.....this makes me very happy..... Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171609 Share on other sites More sharing options...
June 20, 200618 yr comment_171618 Hi Dan:Most likely is the original engine. Engine numbers for 03/72 seem to run from L24-90xxx though early L24-95xxx. Chassis numbers from HLS30 71xxx into HLS30 75xxx O4/72 HLS30-75xxx though HLS30-80xxx and engines L24-95xxx into L24-80xxx.FWIW,Carl Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171618 Share on other sites More sharing options...
June 20, 200618 yr Author comment_171655 thanks for the onfo Carl...once again this site has come through for me...thanks guys.....more questions in the future as the restore continues I'm sureThanks Dan Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171655 Share on other sites More sharing options...
June 22, 200618 yr comment_171981 thanks for the onfo Carl...once again this site has come through for me...thanks guys.....more questions in the future as the restore continues I'm sureThanks DanDan,If you are lucky the original jack and tool kit are still present with the car. If you are very lucky there will be a piece of paper about the size of an index card in the tool bag. Hopefully the date stamp in the Showa format is still visible and that will give you the exact date of one of the last items to be placed in the car before being shipped from Japan. In my 240Z's case the date was 15 August 1970 or 45.8.15 with 45 being the year in the Showa period. The info. is here:http://www.classiczcars.com/forums/showthread.php?p=169039#post169039 Link to comment https://www.classiczcars.com/forums/topic/20480-need-to-know-production-date/#findComment-171981 Share on other sites More sharing options...
