Posted June 20, 200618 yr comment_171614 Hey, stopped down at a junkyard on the way home and found a 89 and 92 300zx both with their differentials... 5 bolt output shafts... also found some late 80s and early 90s 240sx's with differentials also. This is whats needed for V8 swap and LSD right? Any info on this would help a ton!Thanks Link to comment https://www.classiczcars.com/forums/topic/20487-junkyard-differential/ Share on other sites More sharing options...
June 20, 200618 yr comment_171615 Check Hybridz, more people there do the swaps and can direct you...and I think there are a few posts with full lists of required parts. I'm sorry I can't tell you, but you might be able to find it there faster than waiting for a post. Link to comment https://www.classiczcars.com/forums/topic/20487-junkyard-differential/#findComment-171615 Share on other sites More sharing options...
June 20, 200618 yr Author comment_171620 Thanks, I'm searching here and there, but trying to gain some other opinions while I search. Link to comment https://www.classiczcars.com/forums/topic/20487-junkyard-differential/#findComment-171620 Share on other sites More sharing options...
