Posted June 20, 200619 yr comment_171666 I saw this. doesn't look bad for $800 must have done an engine swap or switched to carbs http://cgi.ebay.com/ebaymotors/1977-Datsun-280-Z-5-speed_W0QQitemZ4652974999QQihZ002QQcategoryZ6187QQrdZ1QQcmdZViewItem Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/ Share on other sites More sharing options...
June 21, 200619 yr comment_171732 Wow, i'd do it if it wern't so far away. Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171732 Share on other sites More sharing options...
June 21, 200619 yr comment_171735 I dunno. If you're going to swap to carbs, why flat-tops? Makes me wonder what it really is? Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171735 Share on other sites More sharing options...
June 21, 200619 yr comment_171745 It looks like a little more than an EFI to carb conversion that went bad. It has the wrong radiator for a 77, no carbon cannister, etc. Strange. Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171745 Share on other sites More sharing options...
June 21, 200619 yr comment_171749 That poor car is mess. The seller says "This is not a car you can hop in and drive. needs fluid changes, inspection, and maybe more." Looks to me like this dude started this project and due to not knowing what the hell he was doing, screwed it up big time and now he's trying to unload it. God help the next poor owner that has to straighten out that mess HE made. Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171749 Share on other sites More sharing options...
June 21, 200619 yr Author comment_171762 But is the body worth $800 I ve seen engines on e bay for less then $500 or a rebuild ? is it worth it Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171762 Share on other sites More sharing options...
June 21, 200619 yr comment_171776 it is worth more in parts than anything else. it looks as if there would be too much work to get it in shape. starting over from scratch can be very expensive... Ive seen better in the JY here recently in fact with MUCH less rust and damage Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171776 Share on other sites More sharing options...
June 21, 200619 yr comment_171810 Why would you do the body before your floor boards and such? All show no go? I donno.... Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171810 Share on other sites More sharing options...
June 21, 200619 yr comment_171833 Where'd everyone get $800? The current starting bid is $250...I see this car is relisted...This thing is WAY out of control on the inside, especially the engine bay.I'd consider it for body parts if it weren't in Indiana! Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171833 Share on other sites More sharing options...
June 21, 200619 yr comment_171838 Mat M said: Where'd everyone get $800? The current starting bid is $250...I see this car is relisted...This thing is WAY out of control on the inside, especially the engine bay.I'd consider it for body parts if it weren't in Indiana!Buy it now price was $800 wasn't it?? I noticed it is $600 now. Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171838 Share on other sites More sharing options...
June 22, 200619 yr Author comment_171859 Yes he lowered the buy it now to $600 rent must be dew Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171859 Share on other sites More sharing options...
June 22, 200619 yr comment_171975 mars23z said: But is the body worth $800 I ve seen engines on e bay for less then $500 or a rebuild ? is it worth itIn my estimation: No. You could spend a little more just look on craigslist.org in Ca. and you will find many better rust free candidates. As always buy the very best car you can afford and you will have many less headaches/ heartaches. I know from experience--over 40 Z cars in 15 years. Sometimes it is better to walk away and wait. Link to comment https://www.classiczcars.com/forums/topic/20491-280z-800/#findComment-171975 Share on other sites More sharing options...
