Fire Extinguishers: Why we should all have them
  • 2 months later...
I think I've finally figured out where to mount a fire extinguisher so it's not in the way, is reachable, and you don't have to take the car apart to install it.
I've decided to mount it on a special bracket behind the passenger seat. The bracket will bolt through the deck, so it can be removed easily. You can bolt it flat on the deck or use some standoffs, and depending on how 'beautiful' your mounting bracket is, you may even leave it in the car for shows. Otherwise, the fire extinguisher is stored upright on the wall or a pole in the garage.
Edited by TomoHawk
