I know that this subject is here many times, I did the search, but I need a simple and clea answer,
what are the advantages/disadvantages of Urethane bushings over the rubber ones?
is the bushing kit from VB good to buy? coz shipping from them is easier than MSA for me..
thanx
Urethane-no shock absorbtion, rubber, too much shock absorbtion meaning rubber gives a cushy ride, and Urethane gives a harsh ride. A mix of both makes for a comfortable well handling ride, all urethane gives a very precise but harsh ride. Don't forget Ebay, I picked up the set for $135 shipped.
Will
I second that, most of my front end is urethane. It is very stiff and I feel everything in the wheel. Can't imagine what it would be like if it were a daily driver, but weekends are a lot of fun.
Scott
then I would deffinitely go to rubber bushing! I dont like the tough ride, guys its a japanese car, it is light, if u make it stiffer u shake the hell of it!
maybe a mixture would work since i can use the urethane in some locations where there is no direct stresses, like the control arms bushings?or I'm totally wrong now?:)
thanks for the explainations guys..
BuDavid, you are spot on! Urethane for predominantly horizontal load, rubber for predominantly vertical load-ie steering rack bushings rubber, steering isolator urethane.
Will
If you're looking for the best performance with the least maintenance I would suggest Delrin bushings. It's not widely used so finding premade bushings may be difficult for older cars but it provides a fairly smooth ride without the deflection of rubber and doesn't require grease like the urethane. Bar stock can be found on Ebay and any machine shop with a lathe can mill it within specs!
I have the MSA urethane bushings for my entire front end and the mustache bar in the back and I really like it. It does ride stiffer but not a lot stiffer. The steering wheel is also a more lively but it gives better road feel and I definitely wouldnt consider it annoying.
Just an FYI though, make sure you put a lot of grease on the mustache bar bushing or they will squeak, they squeaked VERY loudly in my case LOL.
I hear a lot about this topic. I am not looking for a luxury ride out of my 240z, but I don't need it to be any more rough than it already is.
I see urethane bushing kits all over the place, but never the rubber bushing kit.
Where does one get all the rubber bushings needed?
Would I need to buy those one at a time from the dealer?
