Hello, I'm new to these boards, but not so new to 280z's. I currently own a 1978 280z that the tail lights all of a sudden will not turn off. This problem just arose. I drive the car maybe once a week. I had to disconnect the battery terminal to disable power. Probably could have just removed a fuse but oh well. Any pointers, any ideas where I should start first. All other lights work fine.
https://www.classiczcars.com/forums/topic/20553-tail-lights-always-on/
Just the brake lights or the brake lights, running lights and turn signals?
Does it effect the back up lights?
If it's just the brake lights, you might have a problem with the switch that contacts the brake lever under the dash. You might want to clarify for the more experienced members and check that switch while you're at it.
Thanks to everyone for their suggestions. I'll check them out when I get home today. Yes only the tail lights/brakelights are on. All other lights are off. If I did not mention it, this is with the car not running and key out of ignition.
