Tail Lights Always On.
last son kal-el
Hello, I'm new to these boards, but not so new to 280z's. I currently own a 1978 280z that the tail lights all of a sudden will not turn off. This problem just arose. I drive the car maybe once a week. I had to disconnect the battery terminal to disable power. Probably could have just removed a fuse but oh well. Any pointers, any ideas where I should start first. All other lights work fine.
Just the brake lights or the brake lights, running lights and turn signals?
Does it effect the back up lights?
If it's just the brake lights, you might have a problem with the switch that contacts the brake lever under the dash. You might want to clarify for the more experienced members and check that switch while you're at it.
Welcome to the club.
Just the tail lights stay on? Not all of the parking lights? They are all fed by the same switch so that seems strange. It seems more likely that the brake lights would stay on.
