Should I be able to measure some resistance on the water temp sensor when I hook up a mutimeter directly to the sensor?
I'm trying to diagnose whether the wires are bad or if the sensor is bad. I replaced the sensor about 3 years ago but I am experiencing a hot start problem. I followed the circuit tests from the EFI bible and did not get the desired results when testing the water temp sensor. Any help would be appreciated. Thanks
Andre
https://www.classiczcars.com/forums/topic/20565-water-temp-sensor-question/
