I'm confused! Your asking "what are like the best coil over out there?" If you want an answer to who makes the best coilovers, you will get various replies. However, if your asking what are like the best coilovers.....you got me! I don't know of anything thats similar to a coilover other than another coilover!!!!?
what are like the best coil over out there? i seen ground control and the msa onesand that about it...and im wondering where can i actually look for some bangin coil overs
Try www.shox.com.
product #045. Ground Control Coil-Over kit 1970 - 1978 Kit contains Eibach ERS springs, no shocks or struts. Lowers car from 0 to 2.5 inches. $399.00 USDs.
So I guess you aren't going racing with the coil-overs if you want some bargain units. If you only want it for more tire clearance then bargain units will do.
If you are racing there are different types depending on the rules of the sanctioning body you are racing with.
Do some research, what makes a coilover, and what makes a good one, there are good ones out there that are not expensive or cheep crap, you can buy high quality parts to assemble your own set online from Coleman Racing Products among others.
Will
The "best" for what?
Road racing
Autocross
Ralley
Drag racing
Drifting
Street driving
I sell some of the "best" for road racing. A complete Penske 8760 triple adjustable, remote resivior strut kit with EMI Racing camber plates, 2.25" OD Hypercoil springs, Hyperco helper springs, threaded collars, etc. for $10,000.00 That is arguably the best that has ever been installed on a 240Z here in the USA.
Some of the other "bests" that I sell are here:
http://www.betamotorsports.com/products/240StrutKit.html
