has anyone used this type of product for the interior of the Z? Go to this link half way down on the page. http://www.mcmaster.com/catalog/109/html/3240.html . For that price I can do the whole inside of the car. Also I read that their damping sheet are the same spes as Dynamat.
https://www.classiczcars.com/forums/topic/20630-vibration-damping-compound/
You might post the number of the item in question.
There are several items on that page.
I used Q-Pads by Evercoat which are an asphalt based sheet with adhesive over the POR I painted on the metal. A friend used Brown Bread, another Dynamat. Different products, basically same function, dampen the harmonic vibration of the sheet metal, which reduces the sound transmitted through the metal.
FWIW
E
I think my first question about 9545T1 is whether it's water-proof once it dries...otherwise with the first spill of anything that has water (coffee, soda, ...) you're looking at a gooey mess.
Otherwise it sounds ok, but I've no experience with it, either industrially or with cars.
Sorry couldn't be more help.
Enrique
