Posted July 5, 200618 yr comment_173465 okay i started my 280z using starter fluid and it starts but until we push the gas pedal it dies......and if we start it it again and spray more starter fluid and push the gas...it doesnt die unless we stop spraying starter fuid and pusing the pedal..any help? Link to comment https://www.classiczcars.com/forums/topic/20674-starting-up/ Share on other sites More sharing options...
July 5, 200618 yr comment_173466 At least you know the problem isn't a spark or timing problem.Fuel and fuel related problems are your starting point.Have you checked the fuel filter? Fuel pump working? Thats the depth of knowledge I have on FI motors.. Link to comment https://www.classiczcars.com/forums/topic/20674-starting-up/#findComment-173466 Share on other sites More sharing options...
July 5, 200618 yr Author comment_173471 fuel pump is working fine and i havent checked the fuel filter...but the car started and idled...but when i gave it gas...it shut off Link to comment https://www.classiczcars.com/forums/topic/20674-starting-up/#findComment-173471 Share on other sites More sharing options...
July 5, 200618 yr comment_173489 When I bought my 78, it had that same problem. It turned out to be a clogged up gas tank. Has you car been sitting a long time without being run? Link to comment https://www.classiczcars.com/forums/topic/20674-starting-up/#findComment-173489 Share on other sites More sharing options...
July 5, 200618 yr comment_173493 Crank the motor over/let the fuel pump work with the fuel pipe disconnected near the engine to see if the fuel is getting to the engine. If it comes through, its something the FI end, If it is not, it could be as said before, clogged gas tank.Ian Link to comment https://www.classiczcars.com/forums/topic/20674-starting-up/#findComment-173493 Share on other sites More sharing options...
July 5, 200618 yr comment_173505 Check the fuel pressure. Link to comment https://www.classiczcars.com/forums/topic/20674-starting-up/#findComment-173505 Share on other sites More sharing options...
July 5, 200618 yr Author comment_173520 or maybe i need to check my fuel filter...the car did sit around for some years well imma check my fuel filter first Link to comment https://www.classiczcars.com/forums/topic/20674-starting-up/#findComment-173520 Share on other sites More sharing options...
