guys putting back together the 280 motor with n47 head for install in boys 240, using his downdraft carb setup and headers,
question is the n47 has 3 screw holes above the intake ports, the outside 2 are for the intake mounts but the center one that isnt used for this setup do I have to plug the holes? also used the gasket for the 240 vs 280 that doesnt hace thecutout for the injectors, asummme this wont cause any problems?
https://www.classiczcars.com/forums/topic/20689-n47-carb-mounting/
Hi Don,
Well having done this myself, the extra hole shouldn't cause a problem unless its drilled through into the head. I don't think they are though. Just leave it empty. Using the gasket for a carbed engine is fine also.
I put a the stock carb setup from a 72 on a 76 engine and it all worked for me. No surprises.
Have fun,
Chris A.
