I'm planning to swap my 260z AT for a MT. I also want to add a 3.9 ZX gear set. Here's the list of parts that I have so far.
4 or 5 Speed Transmission Conversion
(remove AT crank extension)
Pilot bearing/bushing
Engine Plate (2 pieces)
Transmission bolts
Flywheel
2+2 240mm
Coupe 225mm
Clutch
A good clutch for your purposes is the EXEDY 06-801A. It has a heaver
belleville spring and a more agressive disc material than the stock turbo
unit. (EXEDY /Daikin is an OEM by the way) About 60% more capacity than
stock.
Pressure plate
Fasteners (bolts)
Throw out or release bearing
Clutch - Master Cylinder, Need to cut a hole in the firewall for that
Clutch - Slave Cylinder
Fluid lines from the Clutch M.C. to the slave cylinder
Slave cylinder hose
Clutch/Brake pedal assemblies
Shifter
Shifter boot floor
Shifter boot console
Rear trans Mount
Rear cross over
76 up driveshaft
Starter (parts books show difference between AT/MT)
Speedo driven gear at transmission
