Posted July 14, 200618 yr comment_174542 Hi I have a clue.I want to upgrade my brake sist. but Im not sure what to get.MSA have a rear drum brake conversion to disc and also for front brakes have 4 piston calipers and vented/sloted rotors kit.Been looking for wilwood kit that offers Arizonazcar and the look super for me.Im sure some one can drive me the right way.What do you recommend to me as a better brake system.Thank You. Link to comment https://www.classiczcars.com/forums/topic/20794-question-on-brake-kits/ Share on other sites More sharing options...
July 14, 200618 yr comment_174552 From over at HybridZ...http://forums.hybridz.org/showthread.php?t=104735http://forums.hybridz.org/showthread.php?t=103767Basicly after reading these I just decided to keep my system stock since it is fine for normal driving (and in the opinion of some even Auto Cross).Hope these help.... Link to comment https://www.classiczcars.com/forums/topic/20794-question-on-brake-kits/#findComment-174552 Share on other sites More sharing options...
July 18, 200618 yr Author comment_175055 Thank You 280z1975.Plenty of info. Sure Im going to save some money for the moment. Link to comment https://www.classiczcars.com/forums/topic/20794-question-on-brake-kits/#findComment-175055 Share on other sites More sharing options...
July 19, 200618 yr comment_175107 Yes, the stock brakes are good for everyday driving. But as a BSP (SCCA) racer and canyon racer, I can tell you. It gets to be pretty exciting out there, when your brakes go to the floor and you need to slow down. What also was bad, I use to belong to the Colorado Z club and ran with them on the race track at Second Creek (moved back to NC now). It would only take one time on the track to boil the brake fluid. Talk about your pucker power. I have gone to the 300ZX brake rotors w/toyota calibers upfront and 280ZX brake package in the rear (it took me out of the BSP class). I still take it out on the track and haven't had that problem in some time now. Look over all of the sites, most have some pretty good info on them on several brake systems for our car. Just pick the one you like and go for it. Also look into info on brake cooling. Depending on your money situation, you can do it several ways and still get better brakes. I am currently working on a rear setup using a 1989 Olds. grand touring sedan front rotor on the rear. Still looking into what type caliber and mounting bracket, do I want to use. Also working with the 300ZX turbo brake system to see if I can mount them to a Z. Got the rotors off of a car at a pick-and-pull in Greeley, CO for almost nothing. The HybridZ.org site is a real good site for more info on such a subject. Good Luck with what you are looking into. If you decide to change it. Please post it here and tell us all about it. Rich:) Link to comment https://www.classiczcars.com/forums/topic/20794-question-on-brake-kits/#findComment-175107 Share on other sites More sharing options...
July 19, 200618 yr comment_175133 There is two different kits vailable from Motorsport.com Link to comment https://www.classiczcars.com/forums/topic/20794-question-on-brake-kits/#findComment-175133 Share on other sites More sharing options...
July 22, 200618 yr comment_175663 i just got the wilwood kit from AZC...pretty $$$ but they are SOOO SEXY!oh yea...i havent put them on yet, gotta get some wheels to fit over them...thats the only drawback i see, pretty much rules out any 15 inch rims Link to comment https://www.classiczcars.com/forums/topic/20794-question-on-brake-kits/#findComment-175663 Share on other sites More sharing options...
