77-78 hood vents needed
DatsunZsRule
Those look really neat- in a modern sense. Do you think you could put some fins inside, like the OEM ones? It could make it look a little more like OEM, but it also has the newer frame that isn't brittle. I'd bet that only knowledgable people would know the dkifference. Either that or just leave it open for more air flow (assuming they're functional vents.)
The rally hood was interesting... I wonder if you can aim those lamps, and I'll assume the lamps clear the bumper when you open the hood.
The rally hood would most likely clear those lights as you lift it open. As far as the mounting procedure of their vents I'd rather use 3M Automotive Acrylic Mounting Tape than trusting short sheet metal screws in urethane. But I'll just keep my original hood vents, thank you.
  • Who's Online   1 Member, 0 Anonymous, 859 Guests (See full list)
