Posted July 15, 200618 yr comment_174646 I recently purchased a N-66 head from a Nissan/Datsun inventory liquidator on E-Bay.He says it is the equivalent to a 260Z head, and it is NOS. How could I go wrong. Have an F54 short block next to my tired 240Z in Scottsdale, maybe a quick cure?xstates@verizon.net Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/ Share on other sites More sharing options...
July 15, 200618 yr comment_174658 N-66?????? Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174658 Share on other sites More sharing options...
July 15, 200618 yr comment_174670 zguitar71 said: N-66??????I was waiting for that response. I've never heard of such a head. How about some pictures of said beasty. Chris A. Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174670 Share on other sites More sharing options...
July 15, 200618 yr comment_174720 I've never heard of it either. I wonder what it's really from? A later Maxima perhaps, although I thought they used modified versions of the N42 & N47. Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174720 Share on other sites More sharing options...
July 15, 200618 yr Author comment_174724 N-33 looks similar to an E-31 laying around except ports might be a few thousandths larger. Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174724 Share on other sites More sharing options...
July 15, 200618 yr Author comment_174725 N-33 and NOS - jpegs Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174725 Share on other sites More sharing options...
July 15, 200618 yr Author comment_174728 E-31 comparison Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174728 Share on other sites More sharing options...
July 15, 200618 yr Author comment_174731 More #'s on the E-31 Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174731 Share on other sites More sharing options...
July 17, 200618 yr Author comment_174875 started FAST, died slowly???????????????Any answers?Probably cc it and measure ports and seats, an an AB test to the lowly E-31.Actually looks to be exactly what the Dealer said it was. He said many E-Bayer's said no such number.So much for E-Bay experts. I'm biased, many of the E-Bayers who follow Z's and 24/7: beat-up Sellers and never bid. They are "bottom feeders" as aptly written by a member at this site. Next step some Manley SS valves, and Comp Cam kit, have the RB cam, and F-54 short block for a relatively complete engine. Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174875 Share on other sites More sharing options...
July 17, 200618 yr comment_174882 RickX said: Any answers?Ummm....you said you bought a N66 head. But you posted pics of N33 and E31. Where's the pics of the N66? This is the best I can do for you....BORE AND STROKE COMBINATIONS FOR L ENGINES HEAD # VOL. C.C. INT VALV. EX VALV. EXH. PORT PROD. DATE E31 42.4 42 33 square ex 10/69-7/71 E88 44.7 42 33 square ex 9/71-7/72 N33 47.8 42 33 square ex 8/72-7/73 N33/P50 47.8 42 35 square ex 8/73-8/74 N42 44.6 44 35 square ex 9/74-7/77 N47 44.6 44 35 round ex 8/77-3/78 P81 44.6 44 35 round ex 2/79-6/80 P79 53.6 44 35 round ex 7/80- P90 53.6 44 35 square ex 12/80-7/82Turbo P99 53.6 44 35 square ex 8/82-Turbo Hyd Again, I find no N66 anywhere. And I've looked. Chris A. Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174882 Share on other sites More sharing options...
July 17, 200618 yr Author comment_174888 It is N-33, not the other. Intake on a 260Z head is bigger than a 280Z and some ZX's?Thanks for the info, should work well on a back-up engine and its NOS.On the E-31, are the centerlines closer on those small valves than the later heads with bigger valves?rick Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174888 Share on other sites More sharing options...
July 17, 200618 yr comment_174889 RickX said: On the E-31, are the centerlines closer on those small valves than the later heads with bigger valves?rickGood question, I doubt it. It would screw up the location of the lobes on the cam I'd think. I dont have any heads off except a E31 right now or I'd check. I'd think the distance between the valve's OD is probably farther apart on a E31 than say a N47. Chris A. Link to comment https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174889 Share on other sites More sharing options...
