I recently purchased a N-66 head from a Nissan/Datsun inventory liquidator on E-Bay.
He says it is the equivalent to a 260Z head, and it is NOS. How could I go wrong.
Have an F54 short block next to my tired 240Z in Scottsdale, maybe a quick cure?
xstates@verizon.net
https://www.classiczcars.com/forums/topic/20805-z-head/
started FAST, died slowly???????????????
Any answers?
Probably cc it and measure ports and seats, an an AB test to the lowly E-31.
Actually looks to be exactly what the Dealer said it was. He said many E-Bayer's said no such number.
So much for E-Bay experts. I'm biased, many of the E-Bayers who follow Z's and 24/7: beat-up Sellers and never bid. They are "bottom feeders" as aptly written by a member at this site.
Next step some Manley SS valves, and Comp Cam kit, have the RB cam, and F-54 short block for a relatively complete engine.
https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174875
  RickX said:
Any answers?
Ummm....you said you bought a N66 head. But you posted pics of N33 and E31. Where's the pics of the N66?
This is the best I can do for you....
BORE AND STROKE COMBINATIONS FOR L ENGINES HEAD # VOL. C.C. INT VALV. EX VALV. EXH. PORT PROD. DATE
E31 42.4 42 33 square ex 10/69-7/71
E88 44.7 42 33 square ex 9/71-7/72
N33 47.8 42 33 square ex 8/72-7/73
N33/P50 47.8 42 35 square ex 8/73-8/74
N42 44.6 44 35 square ex 9/74-7/77
N47 44.6 44 35 round ex 8/77-3/78
P81 44.6 44 35 round ex 2/79-6/80
P79 53.6 44 35 round ex 7/80-
P90 53.6 44 35 square ex 12/80-7/82Turbo
P99 53.6 44 35 square ex 8/82-Turbo Hyd
Again, I find no N66 anywhere. And I've looked.
Chris A.
https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174882
It is N-33, not the other. Intake on a 260Z head is bigger than a 280Z and some ZX's?
Thanks for the info, should work well on a back-up engine and its NOS.
On the E-31, are the centerlines closer on those small valves than the later heads with bigger valves?
rick
https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174888
rick
Good question, I doubt it. It would screw up the location of the lobes on the cam I'd think. I dont have any heads off except a E31 right now or I'd check. I'd think the distance between the valve's OD is probably farther apart on a E31 than say a N47.
Chris A.
https://www.classiczcars.com/forums/topic/20805-z-head/#findComment-174889
