I was checking my timing on the camshaft and crank pulley at TDC. If the thrust plate mark and the camshaft sprocket mark on the back of sprocket are off a little (like 1/16th of an inch) would that make the car sputter or is it something different. Thanks in advance
EDIT: also, some of my valves are a little too tight. What would this do to the engine?
https://www.classiczcars.com/forums/topic/20845-timing-question/
What my problem is is that it doesnt seem like I have all the power that this engine should get, I cant even roast the tires. The setup is an n42 block with flat tops and a P79 head from an 81 zx, stock cam, ported out intake with a 60mm throttle body and cold air intake. HELP. It idles rough too. I will also do the timing again to see if it helps. I cant find any air leaks and all spark plugs and wires are new, so is the fuel filter and all hoses and cap!
