Posted July 18, 200618 yr comment_175060 Hello All, I just bought a 77 280Z from a gentlemen with my company who was the orginal owner. (Even had a copy of the orginal invoice from 1977 for $8800) Boy am I glad that I came across this site because I'm sure I will have plenty of questions in the future about this car. Thanks in advance to all for providing access to the huge amount of info available on these great cars. Mitch P.S. If someone could recommend a mechanic in the San Francisco Bay Area (preference near Hercules) I would much appreciate it. Here are some pictures of my new Z :-) Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/ Share on other sites More sharing options...
July 18, 200618 yr comment_175062 Nice car, Root Beer Brown!You might look at those wheels, they are referred to as "SIDED" wheels and I may have the name in error BUT the key thing about those wheels is that they are Right and Left sided wheels. Your Left Rear wheel should be on the Right Front and vice versa.OR Your Right Rear to the Left Front.But you might also check and see if there are some "vanes" in the dark portion of the wheel that would either push air OUT from under the car or IN towards the brake. Some of these wheels were designed that way to purportedly help the volume of air / cushion of air underneath the car at higher speeds. And depending on front / side / rear skirts or air packages would purportedly "significantly" increase the amount of down-force of the car. It's sales talk.As it stands, you have the front doing opposite air pushes as well as the back.Another way of looking at it...Look at the wheel, and imagine that the CENTER of the wheel was able to spin for part of a revolution before the OUTER rim began to spin....causing the "spokes" to distort. Your Left Front wheel looks as if it were moving forward, whereas your Left Rear looks as if it were going in reverse. Hard to see the Right hand side, but I'll bet it's Front going backwards and Rear going forward.Arne is the wheel connoisseur and will (hopefully) add to everything I'm posting here. But the reason for posting this, is that your car's wheels look uneven.Enrique Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175062 Share on other sites More sharing options...
July 19, 200618 yr comment_175068 Mitch,Welcome to the club. Sure is a good looking car. Hope you enjoy it and use it. I think the fun is in the use and care. If you get up to the northwest, give a holler. I'm sure a few of us would get to gether for a meal or ? Have a good time and good luck finding a mechanic. Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175068 Share on other sites More sharing options...
July 19, 200618 yr comment_175076 EScanlon said: Arne is the wheel connoisseur and will (hopefully) add to everything I'm posting here. But the reason for posting this, is that your car's wheels look uneven.Hard to say from the small pictures, but they look like Ultra's to me. As I recall it, Enkei may have made that style also. But the Enkei's didn't have a lip on the outside for weights to clip to, and your caps look like Ultra caps as well.Either way, the directional appearance on that style of wheel was for looks only. There was/is no functional fins or other air-moving component to those wheels. It really has no effect on the car or how it drives as to which wheel is where.But if you look at the back sides of the wheels, I think either brand had a recommended side of the car cast in - 'R' or 'L' for the Ultras, the Enkei's might actually have Right and Left cast. Use those as a recommendation, if you prefer the looks of them on the opposite side, go for it.If it were me, I'd swap the right front with the left rear. Or you could swap the left front with the right rear, either way will even things out. Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175076 Share on other sites More sharing options...
July 19, 200618 yr Author comment_175079 Hehehehe.....I noticed that when I bought the car. Owner said he had the tires rotated and forgot to have them matched up until after the fact. It is on my to do list. :-) Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175079 Share on other sites More sharing options...
July 19, 200618 yr comment_175090 You might want to check this place out, they claim to service ALL generations of Z, not really sure, since they don't actually SHOW any from our preffered period. Anyway, check it out and welcome.http://www.zcargarage.com/http://t.webring.com/hub?ring=zcars the webring has all sorts of stuff, I tend to get lost in there, however. Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175090 Share on other sites More sharing options...
July 19, 200618 yr Author comment_175112 Thanks guys for the warm welcome, compliments, and referrals. Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175112 Share on other sites More sharing options...
July 19, 200618 yr comment_175144 Great looking Z she is a great find. Enjoy every mile . And Welcome to the group . there is a ton of knowledge to be tapped here. Gary Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175144 Share on other sites More sharing options...
July 19, 200618 yr comment_175146 Welcome, and enjoy the ride!!Will Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175146 Share on other sites More sharing options...
July 19, 200618 yr comment_175176 Welcome to the fray! Where the heck is Hercules? Never heard of it. Guess it's map time. Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175176 Share on other sites More sharing options...
July 20, 200618 yr Author comment_175370 Hercules is located in the SF Bay Area 20 miles North of Berkeley about 5 miles before the Carquinez Bridge. (For those of you familiar with the area.) I just drove the car to work for the first time and everyone is impressed with the shape that it's in. I was told by my co-workers to ask how much do you guys think a car like this is worth? Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175370 Share on other sites More sharing options...
July 21, 200618 yr comment_175464 Hard to say what it's worth without all the details and more pics, but my guess would be somewhere in the range of $4000 - $5000, of course the real answer is whatever someone would pay for it. Link to comment https://www.classiczcars.com/forums/topic/20855-hello-all/#findComment-175464 Share on other sites More sharing options...
