Posted July 20, 200618 yr comment_175372 I have replaced the fuel regulator, air flow meter, temp sensor and car is still burning up all 6 plugs. Car is currently at Nissan dealer and their don't have a clue. Any suggestion would greatly be appreciated.Ken Link to comment https://www.classiczcars.com/forums/topic/20886-help-76-280z-running-rich/ Share on other sites More sharing options...
July 21, 200618 yr comment_175488 Replace the ECU. Link to comment https://www.classiczcars.com/forums/topic/20886-help-76-280z-running-rich/#findComment-175488 Share on other sites More sharing options...
July 21, 200618 yr comment_175504 Have you downloaded the EFI bible? Will probably help you out some...Having the FSM (Factory Service Manual) for your model year will also help out quite a bit, as the EFI bible makes reference to various sections, page numbers, procedures...etc...etc. You can get the EFI bible at the following url:http://www.72hours.net/~zcarwebdawg1 Link to comment https://www.classiczcars.com/forums/topic/20886-help-76-280z-running-rich/#findComment-175504 Share on other sites More sharing options...
July 21, 200618 yr comment_175581 The best thing to do instead of playing the guessing game which is expensive would be to perform all of the test procedures at the 35 pin connector for the ECU which is listed in the FSM with a multimeter. performing these tests will get you pointed in the right direction to what the cause is. Thats my best suggestion. Hopefully you own a meter and a FSM Link to comment https://www.classiczcars.com/forums/topic/20886-help-76-280z-running-rich/#findComment-175581 Share on other sites More sharing options...
July 22, 200618 yr comment_175596 Also check your spark timing, and make sure your coil is good. Link to comment https://www.classiczcars.com/forums/topic/20886-help-76-280z-running-rich/#findComment-175596 Share on other sites More sharing options...
