Posted July 26, 200618 yr comment_176000 I don’t have a hazard switch/cant find one…and the turn signal power runs though the hazard. So I connected the 2 center green wires in the wiring diagram for the turn signals. Now the turn signals work correctly when I click left or right but when it’s in the center both flash (on the turn signal flasher…. NOT the hazard flasher…I have 2 different flashers so I can heard the difference) It shouldn’t be too hard but what do I need to do to prevent it from flashing when centered? (IE how dose the hazard switch allow power to go to the left and right but not when centered when hazard switch is off?) Link to comment https://www.classiczcars.com/forums/topic/20950-somewhat-easy-wiring-question/ Share on other sites More sharing options...
July 26, 200618 yr comment_176011 Without knowing the year it's hard to say. The wiring varies from year to year. Link to comment https://www.classiczcars.com/forums/topic/20950-somewhat-easy-wiring-question/#findComment-176011 Share on other sites More sharing options...
July 26, 200618 yr comment_176033 Wouldn't it be even easier to simply find the right Hazard Switch for your year?E Link to comment https://www.classiczcars.com/forums/topic/20950-somewhat-easy-wiring-question/#findComment-176033 Share on other sites More sharing options...
July 26, 200618 yr Author comment_176034 Its a 74 and ive been searching for a hazzard switch...if some one finds one for sale let me know. I have the service manuals(ie the diagrams) thats how i know its the 2 center green wirings headed to the hazzard switch. I was hoping i could just bypass the hazzard by connecting them. it works but when i dont have the turn signales going to the left or right it flashs both in stead of none. Link to comment https://www.classiczcars.com/forums/topic/20950-somewhat-easy-wiring-question/#findComment-176034 Share on other sites More sharing options...
July 26, 200618 yr comment_176037 So you are looking for the Pull Style Green Knob Hazard Switch. If I recall correctly, those were available pretty much from 73 on. Anyone out there? Unfortunately, I don't have one.You might also connect the two Green / Yellow wires together, as they conect the Stop Light Switch. While you're at it, disconnect the Hazard Flasher. According to the schematic the Hazard Flasher is only necessary in the circuitry when it's actually on.E Link to comment https://www.classiczcars.com/forums/topic/20950-somewhat-easy-wiring-question/#findComment-176037 Share on other sites More sharing options...
July 26, 200618 yr Author comment_176091 IIRC i tried that and when the switch is centered the lights stay lit up instead of flashing Link to comment https://www.classiczcars.com/forums/topic/20950-somewhat-easy-wiring-question/#findComment-176091 Share on other sites More sharing options...
