Are you talking about a gasoline surge tank for heavy cornering? If so you probably don't need more than about 1/2 liter, just make it tall and skinny. Here's an example: http://forums.hybridz.org/showthread.php?t=94570
Thanks all, surge tank or sometimes called swirl pot, driving with less than 1/2 tank is causing problems on fast switchbacks in the zed, so Ithink I'll fit one under the washer bottle inspection lid. The exhaust tube sounds a good idea and place to find a builder.
