New tach problem - 240Z
Arne
OK, here's a new one on me. The tach in my early '71 240Z (4 wire) suddenly this afternoon started to peg the needle at 8000 RPM any time the key is turned to the Run position, whether the engine is running or not. I suspect a problem with the tach itself, not the wiring as the ignition appears to be working fine, since the car starts and runs normally. Any thoughts?
Sounds logical, but before I install teh other one, can anyone think of anything in the car's wiring that could cause this failure? No sense in doing the same thing to another one, you know.
The diode finally went south? I know (from this forum) that the 240z tach is susceptible to heat when the diode starts to 'wear out'. The tach would slowly climb and then peg itself until it cooled down. The fix was to solder in a new diode that is available from radio shack.
