Posted August 1, 200618 yr comment_176688 I saw this on ebay. I was wondering is it really possible? One SU carb with a turbo?http://cgi.ebay.com/ebaymotors/vintage-datsun-z-car-draw-thru-turbo-setup_W0QQcmdZViewItemQQcategoryZ33742QQihZ003QQitemZ130012174778QQrdZ1 Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/ Share on other sites More sharing options...
August 1, 200618 yr comment_176690 nup, not possible in my opinion. (that's probably why it was listed)!Turbo with side draft webber is the usual working solution to the turbo problem, the best being FI! Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176690 Share on other sites More sharing options...
August 1, 200618 yr comment_176691 I've seen a single SU turbo setup before, but forgot where. I don't think it was a "Turbo Tom" setup though. Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176691 Share on other sites More sharing options...
August 1, 200618 yr comment_176692 Ed,I am sure it is possable, but I question the ability of the single carb to feed a forced induction engine that in normal aspiration needs two! Since there is no identification on the carb/jetting, it could work if they were setup right, but I would hate to have the only way of finding out be sacrificing a set of pistons or more...Putting something like this together would not be too difficult-even adapting a zx dizzy isnt much more involved than modifing one to work on a 240Z.Using the complete exhaust system from a ZX turbo, from the manifold up to to the cat, would take care of the outgoing. Fabricating a "Y" tube to go from the outlet of the turbo to the current carbs(rejetted) would be the most difficult part, but even with what is in the auction, you still have to fabricate some form of air filter and plumbing to connect it to the turbo. After everything was fabbed up, you would have a tuning headache to deal with, but doing the math with a known compressor map and known jets would be easier than the unknowns in the auction.I have a good deal of info on turbocharging through a carb(carbs), and a source for more. WIll Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176692 Share on other sites More sharing options...
August 1, 200618 yr comment_176705 CROWN Mfg. was one of the first to put a Turbo on the Z.. they used the one S.U. in their set-up. As I recall that was around 74 or 75. <a href=http://zhome.com/picturelibrary/turbol24.jpg TARGET=NEW> See Picture Here</A>FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176705 Share on other sites More sharing options...
August 1, 200618 yr comment_176711 they used a jag su, which is a bit larger Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176711 Share on other sites More sharing options...
August 1, 200618 yr comment_176724 Ed, In going through my literature, the pieces in the auction seem to be part of a kit sold by **** Barbour Parts and Accessories For Datsun Z. Check out the attatched scan from their catalog, some of the pieces pictured are dead ringers. Will Yikes-the automated censor software found his first name was pornographic! If you aren't sure what is was, it is a four letter word that begins with "Di" and ends with "ck"! Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176724 Share on other sites More sharing options...
August 1, 200618 yr comment_176729 About a year or so ago, at my friend's shop in Upland, Ca., there was a wrecked 75 or 76 280Z with the 280Z kit in the attachment. I remember discussing it with him. It was complete but the turbo itself was siezed up. Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176729 Share on other sites More sharing options...
August 1, 200618 yr Author comment_176738 Pretty interesting, I would have never thought. Carl, that picture you have looks identical to what's in the kit.I wonder if there are any cars out there that still run with this set-up. Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176738 Share on other sites More sharing options...
August 2, 200618 yr comment_176817 Well.. looks like my memory isn't too good... Here's a comparison in April 72 Road & Track... on the Crown Turbo vs. Stock vs. the BRE C-Production Z. I believe we have an IZCC Member, that is also in the Gateway Z Club - that might still be running his Crown Turbo Set-up. FWIW, Carl B. Carl Beck Clearwater, FL USA http://ZHome.com Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176817 Share on other sites More sharing options...
August 2, 200618 yr comment_176840 It looks like Barbour sold the Crown kit-evidence cast into the plenum.Great find Carl!!Will Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176840 Share on other sites More sharing options...
August 2, 200618 yr comment_176864 The Draw-through SU turbo set-up has been used in several different cars. There was a 2 lt Roadster in the 80's that was wicked fast using a single SU, in front of the turbo.The Constant velocity feature of the SU works well in this set up, but you got to play with the needle profile and dome spring rate to keep from running lean !YIKES! Link to comment https://www.classiczcars.com/forums/topic/21025-turbo-su-setup-on-ebay/#findComment-176864 Share on other sites More sharing options...
